Based on REST principles, the TrendMiner Work Organizer API endpoints provide access to all work created and saved by users like views, searches, formulas, etc.
1. Authentication
Requests to the Work Organizer API can be done authenticated as your client. To do requests, you first need to create a client and request a token.
When you create/update saved items authenticated as your client, they will belong to service-account-CLIENTID.
1.1. Creating a new client
Your client ID
curl --request POST \
200 OK
"expires_in": 300,
"refresh_expires_in": 0,
"token_type": "Bearer",
"scope": "email profile"
1.3. Doing a request with an access token
curl --request GET \
--url 'https://YOUR_DOMAIN/work/[any-api]' \
2. Resources
2.1. AccessRules
2.1.1. Create an access rule for the saved item.
POST /saveditem/{savedItemId}/accessrule
Parameters
Type |
Name |
Description |
Schema |
Path required |
savedItemId |
The saved item for which to create the access rule |
String |
Body required |
SavedItemAccessRuleModel |
The access rule model. |
Responses
HTTP Code |
Description |
Schema |
404 |
The resource was not found |
AccessRuleResource |
201 |
Created |
400 |
Validation failed |
401 |
Unauthorized |
Produces
application/json
2.1.2. Delete an access rule for a saved item
DELETE /saveditem/{savedItemId}/accessrule/{accessRuleId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
savedItemId |
The saved item to which the access rule apply |
String |
Path required |
accessRuleId |
The identifier of the access rule to delete |
UUID |
Responses
HTTP Code |
Description |
Schema |
204 |
No response |
String |
404 |
String |
400 |
Validation failed |
String |
401 |
Unauthorized |
String |
Produces
application/json
2.1.3. Get the access rules for a saved item.
GET /saveditem/{savedItemId}/accessrule
Parameters
Type |
Name |
Description |
Schema |
Path required |
savedItemId |
The saved item to which the access rules apply |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
List[[AccessRuleResource]] |
404 |
400 |
Validation failed |
401 |
Unauthorized |
Produces
application/json
2.2. AdministrativeTile
2.2.1. Add an image
POST /administrative-tile/image
Parameters
Type |
Name |
Description |
Schema |
Query optional |
type |
The mimeType of the image. |
Responses
HTTP Code |
Description |
Schema |
403 |
Forbidden |
ErrorMessage |
200 |
Ok |
404 |
Resource(s) not found! |
401 |
Unauthorized |
Produces
2.2.2. Delete the image
DELETE /administrative-tile/image
Parameters
| Type | Name | Description | Schema |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
403 |
Forbidden |
404 |
401 |
Unauthorized |
2.2.3. Retrieve a administrative tile
GET /administrative-tile
Parameters
Type |
Name |
Description |
Schema |
Query optional |
ignoreExpirationTime |
Ignore the expiration time |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
AdministrativeTile |
404 |
401 |
Unauthorized |
Produces
application/json
2.2.4. Retrieve the image of the administrative tile
GET /administrative-tile/image
Parameters
Type |
Name |
Description |
Schema |
Query optional |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
byte[] |
404 |
byte[] |
401 |
Unauthorized |
byte[] |
Produces
2.2.5. Update administrative tile
PUT /administrative-tile
Parameters
Type |
Name |
Description |
Schema |
Body required |
AdministrativeTileModel |
A model of the item to create |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
403 |
Forbidden |
400 |
Validation failed |
Produces
application/json
2.3. HomeFolders
2.3.1. Delete home folder and all children items
DELETE /homefolder/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The identifier of the home folder that will be removed |
UUID |
Responses
HTTP Code |
Description |
Schema |
204 |
No content |
Object |
501 |
Not yet implemented! |
Object |
403 |
Forbidden |
Object |
404 |
Object |
Produces
2.3.2. Retrieve a list of users home folders
POST /homefolder/search
Parameters
Type |
Name |
Description |
Schema |
Body required |
SearchHomeFolderRequest |
The request API model containing search home folder request and pageable |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
PagedModelHomeFolderResource |
501 |
403 |
Forbidden |
404 |
Produces
application/hal+json
2.4. Permissions
2.4.1. Returns a list of permissions for the saved item for the current logged in user
GET /permissions
Parameters
Type |
Name |
Description |
Schema |
Query optional |
saved-item-identifier |
The identifier of the saved item to fetch permissions.This can be omitted for complex-item-identifier. |
Query optional |
complex-item-identifier |
The external identifier of the complex item to fetch permissions. This will be ignored if saved-item-identifier is present. |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
PermissionsResource |
403 |
Forbidden |
404 |
Resource not found |
Produces
application/json
2.5. Preferences
2.5.1. Create a new preference
POST /preferences
Parameters
Type |
Name |
Description |
Schema |
Body required |
PreferenceModel |
A representation of a preference with name and data to create |
Responses
HTTP Code |
Description |
Schema |
201 |
Created |
PreferenceResource |
400 |
Validation failed |
401 |
Unauthorized |
Produces
application/json
2.5.2. Delete an existing preference for the logged in user
DELETE /preferences/{name}
Parameters
Type |
Name |
Description |
Schema |
Path required |
name |
The name of an existing preference to delete |
String |
Responses
HTTP Code |
Description |
Schema |
204 |
No response |
String |
405 |
Method Not Allowed |
String |
404 |
String |
400 |
Validation failed |
String |
401 |
Unauthorized |
String |
Produces
application/json
2.5.3. Retrieve an existing preference for the logged in user
GET /preferences/{name}
Parameters
Type |
Name |
Description |
Schema |
Path required |
name |
The name of an existing preference to retrieve |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
404 |
401 |
Unauthorized |
Produces
application/json
2.5.4. Retrieve all preferences for the logged in user
GET /preferences
Parameters
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
List[[PreferenceResource]] |
401 |
Unauthorized |
Produces
application/json
2.5.5. Store a list of preferences
POST /preferences/store
Parameters
Type |
Name |
Description |
Schema |
Body required |
PreferenceModel |
A list of preferences to store |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
400 |
Validation failed |
401 |
Unauthorized |
Produces
application/json
2.5.6. Update a preference
PUT /preferences/{name}
Parameters
Type |
Name |
Description |
Schema |
Path required |
name |
The name of an existing preference to update |
String |
Body required |
PreferenceModel |
A representation of a preference with data to update.<br> The name in this model will be ignored. |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
405 |
404 |
400 |
Validation failed |
401 |
Unauthorized |
Produces
application/json
2.6. SavedItemFavorites
2.6.1. Favorite a saved item for the logged in user
POST /favorite
Parameters
Type |
Name |
Description |
Schema |
Body required |
SavedItemFavoriteModel |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
SavedItemFavoriteResource |
403 |
Forbidden |
404 |
Resource not found! |
Produces
application/x-spring-data-compact+json
2.6.2. List all the favorited saved items for the logged in user
GET /favorite
Parameters
Type |
Name |
Description |
Schema |
Query optional |
query |
A query string to search.<br/>Only the name and description of the saved item are searched.<br/>Wildcards (*) are supported on all locations. |
Query optional |
excludeTypes |
A list of saved item types.<br/>These types will be excluded from the result. |
Query optional |
includeTypes |
A list of saved item types.<br/>The result will only contain these types. |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Sorting criteria in the format: property,(asc |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
PagedModelSavedItemResource |
400 |
Validation failed |
Produces
2.6.3. Unfavorite a saved item for the logged in user
DELETE /favorite/{savedItemId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
savedItemId |
The identifier of the saved item that needs to be unfavorited.<br/>This identifier should be a valid UUID. |
String |
Responses
HTTP Code |
Description |
Schema |
204 |
No response |
String |
403 |
Forbidden |
String |
404 |
String |
Produces
application/json
2.7. SavedItemTypes
2.7.1. Retrieves the details of the specified type
GET /saveditemtype/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The name of the saved item type to retrieve details of |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
SavedItemTypeResource |
Produces
2.7.2. List all the available saved item types
GET /saveditemtype
Parameters
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
CollectionModelSavedItemTypeResource |
Produces
2.8. SavedItems
2.8.1. Browse the contents of a folder
GET /saveditem/browse
Parameters
Type |
Name |
Description |
Schema |
Query optional |
parent |
The identifier of the folder you want to browse |
Query optional |
excludeTypes |
Query optional |
includeTypes |
Query optional |
includeData |
Set to true to include the full data object in the result.<br/>Defaults to false |
Query optional |
foldersOnly |
Set to true to only return folders. |
Query optional |
homeFolderByUserId |
Used to find the home folder by id of user |
Query optional |
resolveMostRecentLastUsedInformation |
Used to show most recent usage time, instead of time, when user used it |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
404 |
The resource was not found! |
400 |
Validation failed |
Produces
2.8.2. Copy an existing saved item.
POST /saveditem/{id}/copy
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The identifier of the existing saved item that will be copied |
String |
Body required |
SavedItemModel |
The API model containing the changes to apply to the copied saved item.<br/>Only the name and/or description can be changed |
Responses
HTTP Code |
Description |
Schema |
404 |
SavedItemResource |
403 |
Forbidden |
SavedItemResource |
201 |
Created |
SavedItemResource |
400 |
Validation failed |
SavedItemResource |
Produces
2.8.3. Create a new saved item
POST /saveditem
Parameters
Type |
Name |
Description |
Schema |
Body required |
SavedItemModel |
Responses
HTTP Code |
Description |
Schema |
201 |
Created |
SavedItemResource |
400 |
Validation failed |
SavedItemResource |
Produces
2.8.4. Delete saved item(s)
DELETE /saveditem/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The id's of the saved items to delete |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
DeletedItemsResource |
404 |
Produces
GET /saveditem/allowed-access
===== Parameters
Type |
Name |
Description |
Schema |
Query optional |
user |
Query required |
permission |
Query required |
type |
===== Responses
HTTP Code |
Description |
Schema |
200 |
OK |
ComplexIdList |
===== Produces
application/json
==== Retrieve the full path of a saved item; including the saved item itself
GET /saveditem/{id}/path
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The identifier of the saved item who's full path needs to be retrieved.<br/>This identifier should be a valid UUID. |
String |
Query optional |
startingPosition |
The identifier of the saved item from which we will start to build the path |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
List[[PathComponentResource]] |
403 |
Forbidden |
404 |
===== Produces
==== Retrieve a saved item
GET /saveditem/{id}
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The identifier of the saved item to retrieve.<br/>This identifier should be a valid UUID. |
String |
Query optional |
updateLastUsedInformation |
Optionally set this to false to not have the opening logged into LastUsedInformation.<br/>Defaults to true |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
SavedItemResource |
403 |
Forbidden |
SavedItemResource |
404 |
SavedItemResource |
===== Produces
==== Get hal links to saved items
GET /saveditem
===== Parameters
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
SavedItemHalResource |
403 |
Forbidden |
404 |
===== Produces
==== Move saved item(s) to a folder
PUT /saveditem/{id}/move
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
List |
Query optional |
destination |
The identifier of the destination folder. |
===== Responses
HTTP Code |
Description |
Schema |
404 |
Object |
204 |
Ok |
Object |
406 |
Duplicate item! |
Folder structure invalid! |
===== Produces
==== Patch a saved item
PATCH /saveditem/{id}
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The identifier of the saved item that will be patched |
String |
Body required |
SavedItemModel |
The API model containing the changes to apply to the saved item. Only the extended view properties are checked and the rest will be ignored |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
SavedItemResource |
404 |
SavedItemResource |
400 |
Validation failed |
SavedItemResource |
406 |
Duplicate item! |
===== Produces
==== Search saved items
GET /saveditem/search
===== Parameters
Type |
Name |
Description |
Schema |
Query required |
query |
Query optional |
excludeTypes |
Query optional |
includeTypes |
Query optional |
includeData |
Query optional |
sharedWithMe |
Set to true to filter the results to only show items that are shared with the logged in user.<br/>Defaults to false |
Query optional |
includeSharedWithMe |
Set to true to also include items in the results, that are shared with the logged in user.<br/>Defaults to false |
Query optional |
parent |
Needed as entry point for the search. If not provided, the search will start from the top level folder. |
Query optional |
Query optional |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
400 |
Validation failed |
===== Produces
==== Transfer the ownership of a saved item
POST /saveditem/{id}/transfer-ownership
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The identifier of the saved item that will be changing owner |
String |
Body required |
SavedItemTransferOwnershipModel |
The API model containing the details of the new owner. |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
TransferOwnershipResultResource |
404 |
400 |
Validation failed |
===== Produces
==== Update a saved item
PUT /saveditem/{id}
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The identifier of the saved item that will be updated |
String |
Body required |
SavedItemModel |
The API model containing the changes to apply to the saved item. |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
SavedItemResource |
404 |
SavedItemResource |
400 |
Validation failed |
SavedItemResource |
406 |
Duplicate item! |
===== Produces
=== SavedItemsDemo
==== Create demo saved items for a (new) user
POST /saveditem/demo
===== Parameters
Type |
Name |
Description |
Schema |
Body required |
UserInformationModel |
===== Responses
HTTP Code |
Description |
Schema |
201 |
Created |
Object |
400 |
Validation failed |
Object |
===== Produces
=== SavedItemsExportImport
==== Export saved items
GET /export
===== Parameters
Type |
Name |
Description |
Schema |
Query optional |
username |
The username for which the savedItems need to be exported (default: current user) |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
Object |
403 |
Forbidden |
Object |
===== Produces
==== Retrieve the results from the current or last import
GET /import/result
===== Parameters
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
ImportResult |
===== Produces
==== Import saved items
POST /import
===== Parameters
Type |
Name |
Description |
Schema |
Query optional |
username |
The username for which the savedItems need to be imported (default: current user) |
Query optional |
skip |
when set to true, duplicates will not be imported; when set to false, duplicates will be replaced (default: true) |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
ImportResult |
403 |
Forbidden |
ImportResult |
===== Produces
=== Schedule
==== Creates new schedule
POST /schedule
===== Parameters
Type |
Name |
Description |
Schema |
Body required |
ScheduleModel |
A representation of a schedule to create |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
ScheduleResource |
403 |
Forbidden |
ScheduleResource |
404 |
ScheduleResource |
401 |
Unauthorized |
ScheduleResource |
===== Produces
application/json
==== Delete schedule by it's id
DELETE /schedule/{id}
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The id of schedule we trying to delete |
UUID |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
ScheduleResource |
403 |
Forbidden |
ScheduleResource |
404 |
ScheduleResource |
401 |
Unauthorized |
ScheduleResource |
===== Produces
==== Returns the schedule requested by it's id
GET /schedule/{id}
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The id of schedule we trying to get |
UUID |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
ScheduleResource |
404 |
ScheduleResource |
401 |
Unauthorized |
ScheduleResource |
===== Produces
application/json
==== Returns a list of schedules present in the system
GET /schedule
===== Parameters
Type |
Name |
Description |
Schema |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
PagedModelScheduleResource |
===== Produces
application/json
==== Update schedule
PUT /schedule/{id}
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The id of schedule we trying to update |
UUID |
Body required |
ScheduleModel |
A representation of a schedule to with new values |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
ScheduleResource |
403 |
Forbidden |
ScheduleResource |
404 |
ScheduleResource |
401 |
Unauthorized |
ScheduleResource |
===== Produces
application/json
=== Sessions
==== Create a new session
POST /sessions
===== Parameters
Type |
Name |
Description |
Schema |
Body required |
SessionModel |
A session containing valid JSON data |
===== Responses
HTTP Code |
Description |
Schema |
201 |
Created |
400 |
Validation failed |
401 |
Unauthorized |
===== Produces
application/json
==== Delete an existing session
DELETE /sessions/{identifier}
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
The short url identifier of the session to delete |
String |
===== Responses
HTTP Code |
Description |
Schema |
204 |
No response |
Object |
405 |
Object |
404 |
Object |
400 |
Validation failed |
Object |
401 |
Unauthorized |
Object |
===== Produces
application/json
==== Retrieve a session
GET /sessions/{identifier}
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
The short url identifier of the session to retrieve |
String |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
404 |
401 |
Unauthorized |
===== Produces
application/json
==== Get a session by viewId
GET /sessions
===== Parameters
Type |
Name |
Description |
Schema |
Query required |
viewId |
The viewId of the session |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
404 |
401 |
Unauthorized |
===== Produces
application/json
=== TransferResults
==== Get a list of all the transfer of ownership results
GET /transferresults
===== Parameters
Type |
Name |
Description |
Schema |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
PagedModelTransferOwnershipResultResource |
403 |
Forbidden |
===== Produces
=== WeekSetting
==== Retrieve information about current week setting
GET /week-setting
===== Parameters
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
WeekSetting |
401 |
Unauthorized |
WeekSetting |
===== Produces
application/json
==== Update week setting
PUT /week-setting
===== Parameters
Type |
Name |
Description |
Schema |
Body required |
WeekSettingModel |
A model of the setting to update |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
WeekSetting |
403 |
Forbidden |
WeekSetting |
===== Produces
application/json
== Models
=== AccessRuleResource
Represents an access rule definition
| Field Name | Required | Type | Description | Format |
identifier |
String |
The identifier of the access rule. |
objectId |
X |
String |
The identifier of the object. |
paths |
X |
List of [string] |
An array of paths towards the object. |
subjectId |
X |
String |
The identifier of the subject. |
subjectType |
X |
String |
The type of the subject: USER, GROUP, EVERYONE, GUEST. |
Enum: GUEST, EVERYONE, GROUP, USER, |
permissions |
X |
Set of [string] |
A set of permissions the subject has on the specified object. Can be an empty set. |
Enum: |
userDetailsResource |
UserDetailsResource |
_links |
Map of [Link] |
=== AdministrativeTile
API model of the administrative tile
messageTitle |
String |
A message title for administrative tile |
messageParagraph |
String |
A message paragraph for administrative tile |
contactInformation |
String |
A contact information for administrative tile |
lastModifiedDate |
Date |
A last modified time for administrative tile |
date-time |
isActive |
Boolean |
A flag to indicate if administrative tile is active |
expirationTime |
Date |
Expiration time |
date-time |
_links |
Map of [Link] |
=== AdministrativeTileModel
messageTitle |
String |
messageParagraph |
String |
String |
isActive |
Boolean |
expirationTime |
Date |
Expiration time |
date-time |
=== CollectionModelSavedItemTypeResource
_embedded |
CollectionModelSavedItemTypeResource__embedded |
_links |
Map of [Link] |
=== CollectionModelSavedItemTypeResourceEmbedded
savedItemTypeResourceList |
List of [SavedItemTypeResource] |
=== ComplexIdList
complexItemIds |
List of [string] |
=== DeletedItemsResource
Object to describe the saved items that were deleted
identifiers |
List of [string] |
The identifiers of the deleted items |
_links |
Map of [Link] |
=== ErrorMessage
Represents a tm-context exception
statusCode |
HttpStatusCode |
errorCode |
String |
The specific error code of the exception |
message |
String |
The exception message |
details |
Object |
The details of the exception |
=== HomeFolderResource
identifier |
String |
The identifier of the saved item.<br/>This identifier is a UUID. |
type |
String |
The type of the saved item.<br/>The type indicates what can be stored in the data property. |
Enum: SIMILARITY_SEARCH, VALUE_BASED_SEARCH, CROSS_ASSET_VALUE_BASED_SEARCH, DIGITAL_STEP_SEARCH, AREA_SEARCH, FINGERPRINT, LEGACY_FINGERPRINT, VIEW, TREND_HUB_2_VIEW, FILTER, CONTEXT_LOGBOOK_VIEW, FORMULA, AGGREGATION, DASHBOARD, MONITOR, MACHINE_LEARNING, PREDICTIVE, TOTALIZER, CUSTOM_CALCULATIONS, NOTEBOOK, PIPELINE, |
name |
String |
The name of the saved item. |
description |
String |
The description of the saved item. |
data |
Map of [object] |
A Json Object representing the content of the saved item.<br/>This content is specific to the saved item type.<br/>The data is, by default, only available when retrieving a single saved item.<br/>This behaviour can be overridden in lists by explicitly providing "includeData" in the request URL. |
extendedViewProperties |
Map of [string] |
Key value pairs representing the extended view properties of the saved item.<br/>This content is specific to the saved item type. |
lastModifiedDate |
Date |
The UTC date when the saved item was last modified. |
date-time |
folder |
Boolean |
true if the saved item is a folder; false otherwise. |
shared |
Boolean |
true if the saved item is shared; false otherwise. |
favorite |
Boolean |
true if the saved item is favorited; false otherwise. |
owner |
String |
The name of the saved item's owner. |
ownerUuid |
String |
The UUID of the saved item's owner. |
ownerUserDetails |
parentId |
String |
The UUID of the folder where this saved item can be found.<br/>This folder is a saved item. |
permissions |
Set of [string] |
A list of permissions on the saved item for the current logged in user.<br/>Possible permissions:<br/>* SAVED_ITEM_NO_PERMISSIONS - The item can not be accessed;<br/>* SAVED_ITEM_READ_ITEM - The item can be read;<br/>* SAVED_ITEM_WRITE_ITEM - The item can be updated. |
lastUsedInformation |
LastUsedInformationResource |
complexId |
String |
The UUID of the complex identifier where the complex data of the saved item can be found. |
_links |
Map of [Link] |
=== HttpStatusCode
The httpStatus code of the exception
error |
Boolean |
is4xxClientError |
Boolean |
is5xxServerError |
Boolean |
is1xxInformational |
Boolean |
is2xxSuccessful |
Boolean |
is3xxRedirection |
Boolean |
=== ImportFailure
fileLocation |
String |
typeOfFailure |
String |
message |
String |
itemIdentifier |
String |
itemName |
String |
itemType |
String |
itemLocation |
List of [string] |
=== ImportResult
identifier |
UUID |
uuid |
inProgress |
Boolean |
startTime |
String |
endTime |
String |
severeFailure |
ImportFailure |
totalOfItemsSuccessfullyImported |
Integer |
int32 |
totalOfItemsFailedToImport |
Integer |
int32 |
totalOfSkippedItems |
Integer |
int32 |
totalOfReplacedItems |
Integer |
int32 |
failureDetails |
List of [ImportFailure] |
itemsSkipped |
List of [string] |
itemsReplaced |
List of [string] |
=== LastUsedInformationResource
Details about the way a saved item was last used
timestamp |
Date |
Time of last interaction |
date-time |
type |
String |
Type of interaction |
Enum: CREATED, OPENED, MODIFIED, SHARED, |
=== Link
href |
String |
hreflang |
String |
title |
String |
type |
String |
deprecation |
String |
profile |
String |
name |
String |
templated |
Boolean |
=== LocalTime
The start time of schedule.
hour |
Integer |
int32 |
minute |
Integer |
int32 |
second |
Integer |
int32 |
nano |
Integer |
int32 |
=== PageMetadata
size |
Long |
int64 |
totalElements |
Long |
int64 |
totalPages |
Long |
int64 |
number |
Long |
int64 |
=== PagedModelHomeFolderResource
_embedded |
PagedModelHomeFolderResource__embedded |
_links |
Map of [Link] |
page |
PageMetadata |
=== PagedModelHomeFolderResourceEmbedded
content |
List of [HomeFolderResource] |
=== PagedModelSavedItemResource
_embedded |
PagedModelSavedItemResource__embedded |
_links |
Map of [Link] |
page |
PageMetadata |
=== PagedModelSavedItemResourceEmbedded
content |
List of [SavedItemResource] |
=== PagedModelScheduleResource
_embedded |
PagedModelScheduleResource__embedded |
_links |
Map of [Link] |
page |
PageMetadata |
=== PagedModelScheduleResourceEmbedded
content |
List of [ScheduleResource] |
=== PagedModelTransferOwnershipResultResource
_embedded |
PagedModelTransferOwnershipResultResource__embedded |
_links |
Map of [Link] |
page |
PageMetadata |
=== PagedModelTransferOwnershipResultResourceEmbedded
transferOwnershipResultResourceList |
=== PathComponentResource
The definition of a path component = subset of a savedItem resource
identifier |
String |
parentId |
String |
type |
String |
The type of the saved item. |
folder |
Boolean |
name |
String |
description |
String |
_links |
Map of [Link] |
=== PermissionsResource
Describes a list of permissions
permissions |
List of [string] |
The list of permissions |
owner |
String |
username that owns this item |
ownerId |
String |
userid that owns this item |
_links |
Map of [Link] |
=== PreferenceModel
API model of a preference
name |
X |
String |
A unique name for the preference |
data |
X |
Object |
JSON object containing the definition of the preference |
=== PreferenceResource
Represents a saved user preference
name |
String |
The name of the preference |
data |
Object |
_links |
Map of [Link] |
=== SavedItemAccessRuleModel
API model for an access rule on a SavedItem
subjectId |
String |
The identifier of the subject for which to grant the access rule |
subjectType |
X |
String |
The type of the subject |
permissions |
X |
Set of [string] |
The set of permissions |
Enum: |
autoGenerated |
Boolean |
=== SavedItemFavoriteModel
API model for favoriting a saved item
savedItemId |
String |
=== SavedItemFavoriteResource
A reference to a saved item
savedItemIdentifier |
String |
The identifier of the related saved item.<br/>This identifier is a UUID. |
_links |
Map of [Link] |
=== SavedItemHalResource
The response containing HAL links for a saved item
_links |
Map of [Link] |
=== SavedItemModel
API model for creation or modification of a saved item
id |
String |
parentId |
String |
The UUID of the folder where this saved item can be found.<br/>This folder is a saved item.<br/>When empty, the saved item will be saved in the most top level. |
type |
String |
name |
X |
String |
The name of the savedItem |
description |
String |
The description of the savedItem |
data |
Map of [object] |
A Json Object representing the content of the saved item.<br/>This content is specific to the saved item type. |
Map of [string] |
folder |
Boolean |
true if the saved item is a folder; false otherwise.<br/>A folder can not contain data nor a type.<br/>As a result, both the data and type property will be ignored when a folder is saved. |
=== SavedItemResource
The definition of a saved item
identifier |
String |
type |
String |
name |
String |
description |
String |
data |
Map of [object] |
Map of [string] |
lastModifiedDate |
Date |
date-time |
folder |
Boolean |
shared |
Boolean |
favorite |
Boolean |
owner |
String |
ownerUuid |
String |
ownerUserDetails |
parentId |
String |
permissions |
Set of [string] |
complexId |
String |
_links |
Map of [Link] |
=== SavedItemTransferOwnershipModel
API model for changing the owner of a saved item
transferee |
String |
The identifier of the new owner.<br/>This identifier is a UUID. |
=== SavedItemTypeResource
Represents a SavedItemType definition
name |
String |
description |
String |
category |
String |
_links |
Map of [Link] |
=== ScheduleModel
identifier |
UUID |
The identifier of the schedule. |
uuid |
timeZone |
X |
ScheduleModel_timeZone |
startDay |
X |
String |
Start day of schedule. |
Enum: MONDAY, TUESDAY, WEDNESDAY, THURSDAY, FRIDAY, SATURDAY, SUNDAY, |
name |
X |
String |
The name of the schedule. |
startTime |
X |
LocalTime |
numberOfWorkingDays |
X |
Integer |
The number of working days in schedule. |
int32 |
nameOfShifts |
X |
List of [string] |
Name of shifts in schedule. |
type |
X |
String |
Type fo schedule. |
Enum: FIXED, |
duration |
X |
String |
Duration of shift. |
Enum: 4H, 6H, 8H, 12H, |
=== ScheduleModelTimeZone
The time zone of the schedule.
id |
String |
rules |
ScheduleModel_timeZone_rules |
=== ScheduleModelTimeZoneRules
fixedOffset |
Boolean |
transitions |
transitionRules |
=== ScheduleModelTimeZoneRulesDuration
seconds |
Long |
int64 |
zero |
Boolean |
nano |
Integer |
int32 |
negative |
Boolean |
units |
=== ScheduleModelTimeZoneRulesDurationUnits
durationEstimated |
Boolean |
timeBased |
Boolean |
dateBased |
Boolean |
=== ScheduleModelTimeZoneRulesOffsetBefore
totalSeconds |
Integer |
int32 |
id |
String |
=== ScheduleModelTimeZoneRulesTransitionRules
month |
String |
Enum: JANUARY, FEBRUARY, MARCH, APRIL, MAY, JUNE, JULY, AUGUST, SEPTEMBER, OCTOBER, NOVEMBER, DECEMBER, |
timeDefinition |
String |
Enum: UTC, WALL, STANDARD, |
standardOffset |
ScheduleModel_timeZone_rules_offsetBefore |
offsetBefore |
offsetAfter |
dayOfWeek |
String |
dayOfMonthIndicator |
Integer |
int32 |
localTime |
LocalTime |
midnightEndOfDay |
Boolean |
=== ScheduleModelTimeZoneRulesTransitions
offsetBefore |
offsetAfter |
duration |
ScheduleModel_timeZone_rules_duration |
gap |
Boolean |
dateTimeAfter |
Date |
date-time |
dateTimeBefore |
Date |
date-time |
instant |
Date |
date-time |
overlap |
Boolean |
=== ScheduleResource
Represents a schedule definition
identifier |
UUID |
uuid |
timeZone |
X |
ScheduleResource_timeZone |
startDay |
X |
String |
name |
X |
String |
startTime |
X |
LocalTime |
X |
Integer |
int32 |
nameOfShifts |
X |
List of [string] |
type |
X |
String |
Type of schedule. |
Enum: FIXED, |
duration |
X |
String |
_links |
Map of [Link] |
=== ScheduleResourceTimeZone
id |
String |
rules |
=== SearchHomeFolderRequest
userId |
List of [UUID] |
Collection of user identifiers for searching for their home folders |
uuid |
=== SessionModel
API model of a session
data |
X |
Object |
=== TransferOwnershipResultResource
Represents the result of an ownership transfer of a SavedItem
savedItemId |
UUID |
uuid |
initiator |
UUID |
The identifier of the transfer initiator.<br/>This identifier is a UUID. |
uuid |
transferor |
UUID |
The identifier of the original owner of the saved item.<br/>This identifier is a UUID. |
uuid |
transferee |
UUID |
The identifier of the new owner of the saved item.<br/>This identifier is a UUID. |
uuid |
status |
String |
The status that resulted from the transfer of ownership action. |
Enum: SUCCESS, FAILED, |
_links |
Map of [Link] |
=== UserDetailsResource
Details about a user
userId |
String |
Unique identifier |
userName |
String |
Username |
firstName |
String |
First name |
lastName |
String |
Last name |
=== UserInformationModel
userUuid |
String |
The uuid of the owner of the new demo tag |
=== WeekSetting
API model of the week setting
startOfWeek |
String |
Start day of week |
startOfWorkweek |
String |
Start day of workweek |
workweekDuration |
Integer |
Duration of workweek |
int32 |
_links |
Map of [Link] |
=== WeekSettingModel
startOfWeek |
String |
Start of week |
startOfWorkweek |
String |
Start of workweek |
workweekDuration |
Integer |
int32 |
