Based on REST principles, the TrendMiner Data Sources API endpoints provide access to data source configuration and operations related to synchronization and requesting data from sources.
1. Authentication
When performing actions authenticated as a client, they will belong to service-account-CLIENTID.
1.1. Creating a new client
1.2.1. For your client
Your client ID
curl --request POST \
200 OK
"expires_in": 300,
"refresh_expires_in": 0,
"token_type": "Bearer",
"scope": "email profile"
1.2.2. For a specific user
To retrieve a token to authenticate as a specific user, you will need:
Your client ID
The user’s username
The user’s password
A token is requested from the token endpoint of the authentication service.
--data grant_type=password \
--data client_secret=YOUR_CLIENT_SECRET \
--data username=USERNAME \
--data password=PASSWORD
200 OK
"refresh_token": "eyJhbGciOiJIUzI1NiIsInR5cCIgOiAiSldUIiwia2lkIiA6ICI0M2U1YR...", (2)
"expires_in": 300,
"refresh_expires_in": 1800,
The refresh token can be used to retrieve a new access token for the same session
Using the refresh token
The refresh token can be used to retrieve a new access token for the same session:
--data grant_type=refresh_token \
--data refresh_token=REFRESH_TOKEN
=== Doing a request with an access token
curl --request GET \
--url 'https://YOUR_DOMAIN/ds/[any api]' \
2. Resources
2.1. Asset
2.1.1. Get a specific asset denoted by the provided assetId
GET /datasources/{id}/assets/{assetId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The identifier of the datasource |
UUID |
Path required |
assetId |
The identifier of the asset |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
AssetRepresentation |
404 |
The resource was not found |
501 |
Datasource does not support 'ASSET' capability |
Produces
application/json
2.1.2. Get assets by ids from the tree
POST /datasources/{id}/assets
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Body required |
string |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
List[[AssetRepresentation]] |
404 |
501 |
Produces
application/json
2.1.3. Get all root assets from the tree
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
404 |
Produces
application/json
2.2. Configuration
2.2.1. Get the full list of configuration items
GET /configurations
Parameters
Type |
Name |
Description |
Schema |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Sorting criteria in the format: property,(asc |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
PagedModelConfigurationItemRepresentation |
Produces
application/json
application/hal+json
2.2.2. Get a configuration item by name
GET /configurations/{name}
Parameters
Type |
Name |
Description |
Schema |
Path required |
name |
Name of the configuration item to return |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
Produces
application/json
2.2.3. Update a configuration item.
PUT /configurations/{name}
Parameters
Type |
Name |
Description |
Schema |
Path required |
name |
Name of the configuration item to update |
String |
Query required |
value |
New value to update |
Responses
HTTP Code |
Description |
Schema |
200 |
Successfully updated configuration item |
404 |
The configuration item was not found |
204 |
No Content |
Produces
2.3. Connectors
2.3.1. Create a new connector.
POST /connectors
Parameters
Type |
Name |
Description |
Schema |
Body required |
ConnectorModel |
Responses
HTTP Code |
Description |
Schema |
400 |
Bad Request |
ConnectorRepresentation |
201 |
Created |
Produces
application/json
2.3.2. Delete a connector.
DELETE /connectors/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The identifier of the connector |
UUID |
Responses
HTTP Code |
Description |
Schema |
204 |
No content |
404 |
202 |
Accepted |
2.3.3. Get a list of all connectors
GET /connectors
Parameters
Type |
Name |
Description |
Schema |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
PagedModelConnectorRepresentation |
Produces
application/json
2.3.4. Get the connector for the specified identifier.
GET /connectors/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
404 |
Produces
application/json
2.3.5. Get the version of a connector.
GET /connectors/{id}/version
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
VersionInfo |
404 |
VersionInfo |
Produces
application/json
2.3.6. Get a list of all datasources which belong to a connector
GET /connectors/datasources
Parameters
Type |
Name |
Description |
Schema |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
PagedModelDatasourceRepresentation |
Produces
application/json
2.3.7. Synchronizes a connector.
POST /connectors/{id}/sync
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
404 |
202 |
Accepted |
2.3.8. Test connector connection.
POST /connectors/{id}/test
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
ConnectionTest |
404 |
ConnectionTest |
Produces
application/json
2.3.9. Update a connector.
PUT /connectors/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Body required |
ConnectorModel |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
400 |
Bad Request |
404 |
Produces
application/json
2.4. Context
2.4.1. Returns a list of changed context items in the source system as well as the type of change that happened.
GET /datasources/{id}/context/changes
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Query required |
since |
The start date of the query period. Internet DateTime format, see RFC3339 e.g.: '2012-01-01T00:00:00Z’. |
Query optional |
page |
The page to get. This is a cookie that is returned by a previous call to the /changes endpoint. |
Query optional |
size |
The page size |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
CursorPagedResourcesContextChange |
501 |
Datasource does not support 'CONTEXT' capability |
404 |
Produces
application/json
2.4.2. Get a list of available context fields for the given datasource
GET /datasources/{id}/context/field
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
PagedModelFieldRepresentation |
501 |
404 |
Produces
application/json
2.4.3. Get a context item for the given datasource and context id.
GET /datasources/{id}/context/{contextItemId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Path required |
contextItemId |
The identifier of the contextItem |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
ContextItemRepresentation |
501 |
404 |
Produces
application/json
2.4.4. Get a list of context items for the given datasource
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Query required |
startDate |
Query required |
endDate |
The end date of the query period. Internet DateTime format, see RFC3339 e.g.: '2012-01-01T00:00:00Z’. |
Query optional |
createdAfter |
Returned context items need to be created after this date. Internet DateTime format, see RFC3339 e.g.: '2012-01-01T00:00:00Z’. |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
PagedModelContextItemRepresentation |
501 |
404 |
Produces
application/json
2.4.5. Get a list of context items for the given datasource and context identifiers.
POST /datasources/{id}/context
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Body required |
string |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
501 |
404 |
Produces
application/json
2.4.6. Get a list of available context types for the given datasource
GET /datasources/{id}/context/type
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
PagedModelContextTypeRepresentation |
501 |
404 |
Produces
application/json
2.4.7. Get a list of available context workflows for the given datasource
GET /datasources/{id}/context/workflow
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
PagedModelWorkflowRepresentation |
501 |
404 |
Produces
application/json
2.5. Datasources
2.5.1. Create a new datasource.
POST /datasources
Parameters
Type |
Name |
Description |
Schema |
Body required |
DatasourceModel |
Responses
HTTP Code |
Description |
Schema |
400 |
Bad Request |
404 |
201 |
Created |
Produces
application/json
2.5.2. Delete a datasource.
DELETE /datasources/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Responses
HTTP Code |
Description |
Schema |
204 |
No content |
404 |
202 |
Accepted |
2.5.3. Get the datasource for the specified identifier.
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
404 |
Produces
application/json
2.5.4. Get a list of all datasources
GET /datasources
Parameters
Type |
Name |
Description |
Schema |
Query optional |
type |
The datasource type |
Query optional |
capabilityType |
The capability type |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
Produces
application/json
2.5.5. Search datasources
GET /datasources/search
Parameters
Type |
Name |
Description |
Schema |
Query optional |
types |
Query optional |
capabilityTypes |
Query optional |
name |
The name of the datasource |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
Produces
application/json
2.5.6. Synchronizes datasource time series definitions.
POST /datasources/{id}/sync
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
404 |
202 |
Accepted |
2.5.7. Test datasource connection status.
POST /datasources/test
Parameters
Type |
Name |
Description |
Schema |
Body required |
DatasourceModel |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
ConnectionStatus |
Produces
2.5.8. Test datasource connection status.
POST /datasources/{id}/test
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
ConnectionStatus |
404 |
ConnectionStatus |
Produces
2.5.9. Update a datasource.
PUT /datasources/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Body required |
DatasourceModel |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
400 |
Bad Request |
404 |
Produces
application/json
2.6. Event
2.6.1. Write an event back to the source.
POST /datasources/{id}/events/event
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Body required |
EventModel |
Responses
HTTP Code |
Description |
Schema |
404 |
The datasource id does not exist |
EventRepresentation |
201 |
Created |
501 |
Provider type does not support 'EVENT_WRITE' capability |
500 |
Remote source server exception |
Produces
application/json
2.6.2. Get the event for the specified identifier.
GET /datasources/{id}/event/events/{eventId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Path required |
eventId |
The identifier of the event |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
501 |
Datasource does not support 'EVENT' capability |
404 |
Produces
application/json
2.6.3. Get the event type for the specified identifier.
GET /datasources/{id}/events/type/{typeId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Path required |
typeId |
The identifier of the type |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
EventTypeRepresentation |
501 |
404 |
Produces
application/json
2.6.4. Get all event type definitions
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Query optional |
continuationToken |
cursor |
Query optional |
size |
Query optional |
sort |
Sorting criteria in the format: property(,asc |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
CursorPagedModelEventTypeRepresentation |
501 |
404 |
Produces
application/json
application/stream+json
2.6.5. Get all events after a given date
GET /datasources/{id}/events/event
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Query required |
after |
Events occurring after a specific date. Internet DateTime format, see RFC3339 e.g.: '2012-01-01T00:00:00Z’. |
Query optional |
before |
Events occurring before a specific date. Internet DateTime format, see RFC3339 e.g.: '2012-01-01T00:00:00Z’. |
Query optional |
continuationToken |
cursor |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
CursorPagedModelEventRepresentation |
501 |
404 |
Produces
application/json
2.6.6. Get all events based on a grouping key
GET /datasources/{id}/events/groupedevent
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Query required |
groupingKey |
Events belonging together are grouped by a grouping key |
Query optional |
continuationToken |
cursor |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
501 |
404 |
Produces
application/json
2.6.7. Get the field for the specified identifier.
GET /datasources/{id}/events/field/{fieldId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The identifier for the datasource |
UUID |
Path required |
fieldId |
The identifier for the field |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
EventFieldRepresentation |
501 |
404 |
Produces
application/json
2.6.8. Get all field definitions
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Query optional |
continuationToken |
cursor |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
CursorPagedModelEventFieldRepresentation |
501 |
404 |
Produces
application/json
2.7. ImportedTimeSeries
2.7.1. Delete an imported time series.
DELETE /imported/timeseries/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The identifier of the imported time series |
UUID |
Responses
HTTP Code |
Description |
Schema |
204 |
No content |
404 |
2.7.2. Delete all imported time series.
Parameters
| Type | Name | Description | Schema |
Responses
HTTP Code |
Description |
Schema |
204 |
No content |
404 |
2.7.3. Get the imported time series by specified id.
GET /imported/timeseries/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
ImportedTimeSeriesRepresentation |
404 |
Produces
application/json
2.7.4. Search the imported time series.
Parameters
Type |
Name |
Description |
Schema |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
PagedModelImportedTimeSeriesRepresentation |
Produces
application/json
2.7.5. Imports time series from a csv file
POST /imported/timeseries
Parameters
Responses
HTTP Code |
Description |
Schema |
422 |
Validation error |
List[[NotImportedTimeSeries]] |
204 |
Valid |
400 |
Bad Request |
200 |
OK |
Produces
2.8. LegacyTimeSeries
2.8.1. Get the timeseries definition for the specified id
GET /legacy-timeseries/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The identifier of the timeseries definition |
UUID |
Query optional |
fetchStates |
Should fetch states |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
LegacyTagDetailsModel |
404 |
Produces
application/json
2.8.2. Get timeseries definition accessibility details.
GET /legacy-timeseries/accessibility
Parameters
Type |
Name |
Description |
Schema |
Query required |
tagName |
The name of the timeseries definition |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
LegacyAccessibilityModel |
404 |
Produces
application/json
2.8.3. Get the timeseries definition by name query parameter.
Parameters
Type |
Name |
Description |
Schema |
Query required |
tagName |
Query optional |
fetchStates |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
404 |
Produces
application/json
2.8.4. Get all states of the timeseries definition by id query parameter.
GET /legacy-timeseries/{id}/states
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The id of the timeseries definition |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
List[[LegacyStateModel]] |
404 |
Produces
application/json
2.9. MetricsController
GET /datasources/{id}/metrics
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
===== Responses
HTTP Code |
Description |
Schema |
200 |
OK |
MetricRepresentation |
===== Produces
application/json
=== Providers
==== Get a list of all providers and their metadata
GET /providers
===== Parameters
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
===== Produces
application/json
==== Get a provider and its metadata
GET /providers/{name}
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
name |
String |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
ProviderMetaDataRepresentation |
===== Produces
application/json
=== TimeSeries
==== EXPERIMENTAL - basic search
POST /timeseries/basicsearch
===== Parameters
Type |
Name |
Description |
Schema |
Body required |
BasicSearchRequest |
===== Responses
HTTP Code |
Description |
Schema |
200 |
OK |
CollectionModelTimeSeriesDefinitionRepresentation |
===== Produces
application/json
==== EXPERIMENTAL - advanced search
POST /timeseries/advancedsearch
===== Parameters
Type |
Name |
Description |
Schema |
Body required |
AdvancedSearchRequest |
===== Responses
HTTP Code |
Description |
Schema |
200 |
OK |
===== Produces
application/json
==== Search the time series definition by name and description patterns
GET /timeseries/advanced
===== Parameters
Type |
Name |
Description |
Schema |
Query optional |
nameSearchPattern |
Pattern to search time series definitions by name. |
Query optional |
descriptionSearchPattern |
Pattern to search time series definitions by description. |
Query optional |
historians |
Pattern to search time series definitions by description |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
PagedModelTimeSeriesDefinitionRepresentation |
===== Produces
application/json
==== Check whether the logged in user is allowed to read the time series.
GET /timeseries/{id}/accessibility
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
The identifier of the time series definition |
UUID |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
String |
===== Produces
application/json
==== Create a new time series definition.
POST /timeseries
===== Parameters
Type |
Name |
Description |
Schema |
Body required |
TimeSeriesDefinitionModel |
===== Responses
HTTP Code |
Description |
Schema |
400 |
Bad Request |
201 |
Created |
===== Produces
application/json
==== Delete time series definitions.
DELETE /timeseries/{ids}
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
ids |
The id's of the time series |
UUID |
===== Responses
HTTP Code |
Description |
Schema |
204 |
No content |
404 |
==== Deletes a time series definition by datasource id and external id
DELETE /timeseries
===== Parameters
Type |
Name |
Description |
Schema |
Query required |
datasourceId |
Query required |
externalId |
The external identifier of the time series. |
===== Responses
HTTP Code |
Description |
Schema |
204 |
No content |
404 |
==== Get the value mapping for the specified time series, string or int value. If stringValue is present and autocreate=true - new value mapping entry will be created
GET /timeseries/{id}/valuemapping
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Query optional |
intValue |
Int value of value mapping |
Query optional |
stringValue |
String value of value mapping |
Query optional |
autocreate |
Create new value mapping if string value is not present for requested time series definition |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
TimeSeriesValueMappingRepresesentation |
404 |
===== Produces
application/json
==== Get the time series definition for the specified identifier.
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
404 |
===== Produces
application/json
==== Get the time series definition for the specified identifier with dependency tree.
GET /timeseries/{id}/dependency-tree
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
TimeSeriesDependencyTreeDefinitionRepresentation |
404 |
===== Produces
application/json
==== Get the time series definition by external id for the specified identifier with dependency tree.
GET /timeseries/dependency-tree
===== Parameters
Type |
Name |
Description |
Schema |
Query required |
datasourceId |
The identifier of the datasource. |
Query required |
externalId |
The external identifier of the time series definition |
Query optional |
deletedAllowed |
Allow deleted time series definition |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
404 |
===== Produces
application/json
==== Get the time series definitions relations.
GET /timeseries/relations
===== Parameters
Type |
Name |
Description |
Schema |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
PagedModelTimeSeriesRelationRepresentation |
===== Produces
application/json
==== Get all digital states for the specified time series.
GET /timeseries/{id}/valuesmapping
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
PagedModelTimeSeriesValueMappingRepresesentation |
404 |
===== Produces
application/json
==== Get the digital states by intValue for the specified time series.
POST /timeseries/{id}/valuesmapping
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Body required |
ValueMappingRequestModel |
Model containing the identifiers of the value mappings in a int list |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
404 |
===== Produces
application/json
==== Effective index horizon
GET /timeseries/indexhorizon
===== Parameters
===== Responses
HTTP Code |
Description |
Schema |
200 |
OK |
IndexHorizonRepresentation |
===== Produces
application/json
==== Search the time series definition with rsql.
POST /timeseries/search
===== Parameters
Type |
Name |
Description |
Schema |
Query optional |
deletedAllowed |
True if deleted time series should be returned |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Body required |
RsqlRequest |
===== Responses
HTTP Code |
Description |
Schema |
200 |
OK |
===== Produces
application/json
==== Search the time series definitions
GET /timeseries
===== Parameters
Type |
Name |
Description |
Schema |
Query optional |
searchPattern |
Pattern to search time series definitions. Cannot be used at the same time as name parameter. |
Query optional |
name |
The name of the time series definitions to search for. Cannot be used at the same time as searchPattern parameter. |
Query optional |
deletedAllowed |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
===== Produces
application/json
==== Search digital states for the specified time series with rsql.
POST /timeseries/{id}/valuesmapping/search
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Body required |
RsqlRequest |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
404 |
===== Produces
application/json
==== Update a time series definition.
PUT /timeseries/{id}
===== Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Body required |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
400 |
Bad Request |
404 |
201 |
Created |
===== Produces
application/json
==== Update a time series definition by datasource id and external id.
PUT /timeseries
===== Parameters
Type |
Name |
Description |
Schema |
Query required |
datasourceId |
Query required |
externalId |
Body required |
===== Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
400 |
Bad Request |
404 |
201 |
Created |
===== Produces
application/json
== Models
=== AdvancedSearchRequest
| Field Name | Required | Type | Description | Format |
name |
String |
description |
String |
datasources |
List of [UUID] |
uuid |
=== Asset
identifier |
String |
parentIdentifier |
String |
type |
String |
template |
Template |
data |
Data |
name |
String |
description |
String |
=== AssetRepresentation
identifier |
String |
parentIdentifier |
String |
type |
String |
children |
List of [Asset] |
template |
Template |
data |
oneOf<DataReferenceData,NumericData,StringArrayData,StringData> |
name |
String |
description |
String |
links |
List of [Link] |
=== BasicSearchRequest
query |
X |
String |
datasources |
List of [UUID] |
uuid |
=== BoolCapabilityProperty
name |
String |
label |
String |
type |
String |
Enum: SINGLE_LINE, MULTI_LINE, BOOL, DROPDOWN, BOOL_GROUP, |
capabilities |
List of [string] |
Enum: |
required |
Boolean |
=== BoolGroupCapabilityProperty
name |
String |
label |
String |
type |
String |
capabilities |
List of [string] |
Enum: |
required |
Boolean |
groupType |
String |
=== BoolGroupCapabilityPropertyAllOf
groupType |
String |
=== CapabilitiesModel
canChangeInterpolationType |
Boolean |
=== CapabilityProperty
name |
String |
label |
String |
type |
String |
capabilities |
List of [string] |
Enum: |
required |
Boolean |
=== CollectionModelTimeSeriesDefinitionRepresentation
links |
List of [Link] |
content |
=== Component
identifier |
String |
type |
String |
Enum: TAG, ATTRIBUTE, ASSET, |
=== ComponentModel
identifier |
String |
type |
String |
=== ConfigurationItemRepresentation
name |
String |
value |
String |
description |
String |
createdBy |
String |
createOn |
Date |
date-time |
modifiedBy |
String |
modifiedOn |
Date |
date-time |
links |
List of [Link] |
=== ConnectionStatus
healthy |
Boolean |
=== ConnectionTest
networkLatency |
Long |
int64 |
connectionSpeed |
Long |
int64 |
retriesCount |
Long |
int64 |
=== ConnectorModel
name |
X |
String |
description |
String |
host |
X |
String |
username |
String |
password |
String |
maxConnections |
Integer |
int32 |
=== ConnectorRepresentation
name |
String |
description |
String |
status |
String |
Enum: ACTIVE, DELETED, SYNC_IN_PROGRESS, SYNC_ERROR, NOT_SYNCABLE, |
statusDescription |
String |
host |
String |
username |
String |
password |
String |
syncedBy |
String |
syncedOn |
Date |
date-time |
createdBy |
String |
createOn |
Date |
date-time |
modifiedBy |
String |
modifiedOn |
Date |
date-time |
connectorId |
UUID |
uuid |
links |
List of [Link] |
=== ContextChange
changedItem |
ContextItem |
changeType |
String |
Enum: ADD, MODIFY, DELETE, |
=== ContextItem
identifier |
String |
name |
String |
description |
String |
type |
ContextTypeItem |
events |
List of [Event] |
components |
List of [Component] |
fields |
List of [map] |
keywords |
List of [string] |
lastModifiedDate |
String |
errors |
List of [Error] |
=== ContextItemRepresentation
identifier |
String |
name |
String |
description |
String |
type |
ContextTypeItemModel |
events |
List of [EventModel] |
components |
List of [ComponentModel] |
fields |
List of [map] |
keywords |
List of [string] |
lastModifiedDate |
String |
errors |
List of [ErrorModel] |
links |
List of [Link] |
=== ContextTypeItem
identifier |
String |
name |
String |
workflowIdentifier |
String |
=== ContextTypeItemModel
identifier |
String |
name |
String |
String |
=== ContextTypeRepresentation
identifier |
String |
name |
String |
workflow |
IdentifierModel |
color |
String |
fields |
List of [IdentifierModel] |
links |
List of [Link] |
=== CursorPageMetadata
size |
Long |
int64 |
hasNext |
Boolean |
continuationToken |
String |
=== CursorPagedModelEventFieldRepresentation
links |
List of [Link] |
content |
List of [EventFieldRepresentation] |
page |
CursorPageMetadata |
=== CursorPagedModelEventRepresentation
links |
List of [Link] |
content |
List of [EventRepresentation] |
page |
=== CursorPagedModelEventTypeRepresentation
links |
List of [Link] |
content |
List of [EventTypeRepresentation] |
page |
=== CursorPagedResourcesContextChange
content |
List of [ContextChange] |
nextPage |
String |
=== Data
type |
String |
Enum: DATA_REFERENCE, STRING_ARRAY, NUMERIC, STRING, |
value |
Object |
=== DataReferenceData
type |
String |
value |
String |
=== DataReferenceDataAllOf
value |
String |
=== DatasourceModel
type |
X |
String |
name |
X |
String |
description |
String |
connectorId |
UUID |
uuid |
datasourceId |
UUID |
uuid |
maxConnections |
Integer |
int32 |
onlySupportsRawValues |
Boolean |
maxPlotPeriodInDays |
Integer |
int32 |
capabilityTypes |
Set of [string] |
providerTypeProperties |
Set of [ProviderTypePropertyModel] |
=== DatasourceRepresentation
type |
String |
name |
String |
description |
String |
maxConnections |
Integer |
int32 |
Boolean |
status |
String |
statusDescription |
String |
syncedBy |
String |
syncedOn |
Date |
date-time |
createdBy |
String |
createOn |
Date |
date-time |
modifiedBy |
String |
modifiedOn |
Date |
date-time |
indexingGranularity |
String |
Integer |
int32 |
capabilityTypes |
Set of [string] |
Enum: |
connectorId |
UUID |
uuid |
builtin |
Boolean |
datasourceId |
UUID |
uuid |
links |
List of [Link] |
=== Dependency
identifier |
UUID |
uuid |
externalIdentifier |
String |
datasourceIdentifier |
UUID |
uuid |
datasourceType |
String |
dependents |
List of [Dependency] |
dependencies |
=== DropDownCapabilityProperty
name |
String |
label |
String |
type |
String |
capabilities |
List of [string] |
Enum: |
required |
Boolean |
options |
List of [DropDownOption] |
=== DropDownCapabilityPropertyAllOf
options |
=== DropDownOption
key |
String |
value |
String |
=== Error
type |
String |
key |
String |
message |
String |
=== ErrorModel
type |
String |
key |
String |
message |
String |
=== Event
identifier |
String |
occurred |
String |
state |
String |
=== EventFieldRepresentation
identifier |
String |
name |
String |
type |
String |
Enum: STRING, NUMERIC, ENUMERATION, |
placeholder |
String |
options |
List of [string] |
links |
List of [Link] |
=== EventModel
identifier |
String |
name |
String |
description |
String |
type |
EventTypeModel |
state |
String |
occurredAt |
Date |
date-time |
modifiedAt |
Date |
date-time |
components |
fields |
List of [map] |
keywords |
List of [string] |
errors |
groupingKey |
String |
=== EventRepresentation
identifier |
String |
name |
String |
description |
String |
type |
EventType |
state |
String |
occurredAt |
Date |
date-time |
modifiedAt |
Date |
date-time |
components |
fields |
List of [map] |
keywords |
List of [string] |
errors |
List of [Error] |
groupingKey |
String |
links |
List of [Link] |
=== EventType
identifier |
String |
name |
String |
color |
String |
startState |
String |
endState |
String |
states |
List of [string] |
fields |
List of [Identifier] |
=== EventTypeModel
identifier |
String |
name |
String |
color |
String |
startState |
String |
endState |
String |
states |
List of [string] |
fields |
write |
Boolean |
=== EventTypeRepresentation
identifier |
String |
name |
String |
color |
String |
startState |
String |
endState |
String |
states |
List of [string] |
fields |
links |
List of [Link] |
=== FieldRepresentation
identifier |
String |
name |
String |
type |
String |
placeholder |
String |
options |
List of [string] |
links |
List of [Link] |
=== HistorianDetailsModel
dbId |
String |
name |
String |
server |
String |
=== Identifier
identifier |
String |
=== IdentifierModel
identifier |
String |
=== ImportedTimeSeriesRepresentation
identifier |
UUID |
uuid |
name |
String |
description |
String |
unitOfMeasurement |
String |
timeSeriesType |
String |
Enum: ANALOG, DIGITAL, DISCRETE, STRING, |
createOn |
Date |
date-time |
links |
List of [Link] |
=== IndexHorizonRepresentation
links |
List of [Link] |
horizon |
Date |
date-time |
=== LegacyAccessibilityModel
accessibility |
String |
Enum: accessible, denied, deleted, undefined, |
=== LegacyStateModel
Name |
String |
Code |
Integer |
int32 |
Offset |
Integer |
int32 |
=== LegacyTagDetailsModel
id |
String |
name |
String |
description |
String |
interpolationType |
String |
units |
String |
source |
String |
startDate |
Date |
date-time |
endDate |
Date |
date-time |
deleted |
Boolean |
capabilities |
CapabilitiesModel |
historian |
HistorianDetailsModel |
Type |
String |
States |
List of [LegacyStateModel] |
type |
String |
Name |
String |
TagName |
String |
=== Link
rel |
String |
href |
String |
hreflang |
String |
media |
String |
title |
String |
type |
String |
deprecation |
String |
profile |
String |
name |
String |
=== MetricRepresentation
datasourceId |
UUID |
uuid |
datasourceIndex95pInMillis |
Long |
int64 |
datasourceIndex50pInMillis |
Long |
int64 |
datasourcePlot95pInMillis |
Long |
int64 |
datasourcePlot50pInMillis |
Long |
int64 |
datasourceSync95pInMillis |
Long |
int64 |
datasourceSync50pInMillis |
Long |
int64 |
connectorId |
UUID |
uuid |
connectorIndex95pInMillis |
Long |
int64 |
connectorIndex50pInMillis |
Long |
int64 |
connectorPlot95pInMillis |
Long |
int64 |
connectorPlot50pInMillis |
Long |
int64 |
connectorSync50pInMillis |
Long |
int64 |
connectorSync95pInMillis |
Long |
int64 |
links |
List of [Link] |
=== MultiLineCapabilityProperty
name |
String |
label |
String |
type |
String |
capabilities |
List of [string] |
Enum: |
required |
Boolean |
placeholder |
String |
=== MultiLineCapabilityPropertyAllOf
placeholder |
String |
=== NotImportedTimeSeries
tagName |
String |
reason |
String |
details |
Map of [string] |
=== NumericData
type |
String |
value |
BigDecimal |
=== NumericDataAllOf
value |
BigDecimal |
=== PageMetadata
size |
Long |
int64 |
totalElements |
Long |
int64 |
totalPages |
Long |
int64 |
number |
Long |
int64 |
=== PagedModelConfigurationItemRepresentation
links |
List of [Link] |
content |
page |
PageMetadata |
=== PagedModelConnectorRepresentation
links |
List of [Link] |
content |
List of [ConnectorRepresentation] |
page |
PageMetadata |
=== PagedModelContextItemRepresentation
links |
List of [Link] |
content |
List of [ContextItemRepresentation] |
page |
PageMetadata |
=== PagedModelContextTypeRepresentation
links |
List of [Link] |
content |
List of [ContextTypeRepresentation] |
page |
PageMetadata |
=== PagedModelDatasourceRepresentation
links |
List of [Link] |
content |
List of [DatasourceRepresentation] |
page |
PageMetadata |
=== PagedModelFieldRepresentation
links |
List of [Link] |
content |
List of [FieldRepresentation] |
page |
PageMetadata |
=== PagedModelImportedTimeSeriesRepresentation
links |
List of [Link] |
content |
page |
PageMetadata |
=== PagedModelTimeSeriesDefinitionRepresentation
links |
List of [Link] |
content |
page |
PageMetadata |
=== PagedModelTimeSeriesRelationRepresentation
links |
List of [Link] |
content |
page |
PageMetadata |
=== PagedModelTimeSeriesValueMappingRepresesentation
links |
List of [Link] |
content |
page |
PageMetadata |
=== PagedModelWorkflowRepresentation
links |
List of [Link] |
content |
List of [WorkflowRepresentation] |
page |
PageMetadata |
=== ProviderMetaDataRepresentation
name |
String |
label |
String |
experimental |
Boolean |
connectors |
List of [string] |
capabilities |
Set of [string] |
Enum: |
properties |
links |
List of [Link] |
=== ProviderTypePropertyModel
name |
X |
String |
value |
String |
encrypted |
Boolean |
=== ProviderTypePropertyRepresentation
name |
String |
value |
String |
encrypted |
Boolean |
links |
List of [Link] |
=== RsqlRequest
query |
X |
String |
=== SingleLineCapabilityProperty
name |
String |
label |
String |
type |
String |
capabilities |
List of [string] |
Enum: |
required |
Boolean |
placeholder |
String |
encrypted |
Boolean |
=== SingleLineCapabilityPropertyAllOf
placeholder |
String |
encrypted |
Boolean |
=== StringArrayData
type |
String |
value |
List of [string] |
=== StringArrayDataAllOf
value |
List of [string] |
=== StringData
type |
String |
value |
String |
=== Template
identifier |
String |
name |
String |
=== TimeSeriesDefinitionModel
id |
UUID |
uuid |
datasourceId |
X |
UUID |
uuid |
externalId |
String |
name |
X |
String |
description |
String |
type |
X |
String |
dependentTimeSeriesDefinitions |
List of [UUID] |
uuid |
=== TimeSeriesDefinitionRepresentation
datasourceId |
UUID |
uuid |
ownerId |
String |
externalId |
String |
name |
String |
description |
String |
type |
String |
units |
String |
interpolationType |
String |
datasourceType |
String |
deleted |
Boolean |
plotDataUrl |
String |
indexDataUrl |
String |
links |
List of [Link] |
id |
UUID |
uuid |
=== TimeSeriesDependencyTreeDefinitionRepresentation
dependents |
dependencies |
links |
List of [Link] |
=== TimeSeriesRelationRepresentation
timeSeriesId |
UUID |
uuid |
timeSeriesExternalId |
String |
timeSeriesDatasourceId |
UUID |
uuid |
relationTimeSeriesId |
UUID |
uuid |
relationTimeSeriesExternalId |
String |
relationTimeSeriesDatasourceId |
UUID |
uuid |
links |
List of [Link] |
=== TimeSeriesValueMappingRepresesentation
timeSeriesId |
UUID |
uuid |
stringValue |
String |
intValue |
Integer |
int32 |
links |
List of [Link] |
=== ValueMappingRequestModel
intValues |
List of [integer] |
int32 |
=== VersionInfo
version |
String |
=== WorkflowRepresentation
identifier |
String |
name |
String |
startState |
String |
endState |
String |
states |
List of [string] |
links |
List of [Link] |
