Based on simple REST principles, the TrendMiner Assets API endpoints return JSON metadata about assets and attributes in the TrendMiner platform.
1. Authentication
When performing actions authenticated as a client, they will belong to service-account-CLIENTID.
1.1. Creating a new client
Your client ID
curl --request POST \
200 OK
"expires_in": 300,
"refresh_expires_in": 0,
"token_type": "Bearer",
"scope": "email profile"
1.3. Doing a request with an access token
curl --request GET \
--url 'https://YOUR_DOMAIN/af/asset' \
2. Assets
The base object in the Assets universe is the asset. An asset represents a piece of equipment in a plant, ranging from the plant itself to the smallest sensor inside. An asset has a name and a description, along with some other properties.
There are two main types: ASSET and ATTRIBUTE: while an ASSET would be defined as a component of the installation, an ATTRIBUTE would be defined as a property on that asset. Those properties are usually pointers to certain tags containing timeseries data.
To define the asset structure of a (part of a) plant, we need a way to define the parent-child relationships between the different assets. This is done in the form of long paths. An asset has a list of (long) paths over which it can be reached. The long path is built with the identifiers of the parent and ancestor assets of the asset, all the way up to the root of the tree.
Next to the long paths array, a simpler and short paths array is present as well. The shorter paths refer to the same parents and ancestors, but simply with shorter identifiers.
An asset can have multiple paths because it can occur in more than one location in an asset tree.
Paths and long paths can be used interchangeable in the API. Within the same request using paths, all provided paths need to either be long paths or short paths.
Apart from the ASSET and ATTRIBUTE type, a special type called ASSET_ROOT is available. For every asset tree, one asset of this type is generated. It has the same name as the source in which it is defined, and is the highest ancestor of every asset in the tree.
3. Access rules
To restrict access to certain assets, access rules can be assigned to assets and attributes. For simplicity, both assets and attributes will be called assets.
There are three different permissions defined:
user can see the asset, but can’t read its context items |
user can see the asset and read its context items |
user explicitly has no access to the asset |
For clarity, the prefix ASSET_ will be omitted in the remainder of this documentation, unless needed or specified otherwise.
The above permissions can be granted to subjects, the subject types:
unauthenticated users |
all authenticated users |
all users in a given group |
a given user |
In the current release, the subject types GUEST and GROUP cannot be used yet.
When defining an access rule on an asset, a combination of a subject and a set of permissions needs to be provided.
When using the USER subject type, additionally a user id needs to be provided.
3.1. Subject type priorities
Access rules are prioritized by subject type, meaning an access rule on USER has precedence over an access rule defined on EVERYONE (and so on when the other subject types will be implemented).
The following access rules exist:
permissions
BROWSE,READ_CONTEXT_ITEMon asset Pump A for subject typeEVERYONE, -
permissions
BROWSEon asset Pump A for subject typeUSERfor user Bob.
This will result in Bob having the permission BROWSE for that asset, while other users also have the READ_CONTEXT_ITEM permission.
3.2. Inheritance of permissions
When no permissions that apply to the user are defined on an asset, there are still asset permissions that can come from child or parent assets in the tree.
Firstly, all it’s ancestors will be checked to see if any of them have permissions that apply to the user. If there are, the asset will have the same permissions (e.g. if the parent has READ permissions, the asset will also have READ permissions). This is what is referred to as "inheritance".
If no inherited permissions are found, then its children are checked. If any of its children have permissions, then the asset will automatically get the BROWSE permission. This is done so a user can always navigate to any asset it has permissions on. This is what is referred to as "pull-up permissions".
Finally, when there are no pull-up permissions, the current user does not have access to the requested asset.
Users with administrator rights will always have all possible permissions available. |
3.3. No Permission
Due to the inheritance of the permissions, an additional permission type has been foreseen to stop propagation of permissions and to explicitly deny access to an asset. When an access rule is defined with the NO_PERMISSION permission, the user explicitly is revoked access.
Observe the below defined asset tree and the access rules on them.
| Asset tree | Access rules |
The user will have BROWSE and READ_CONTEXT_ITEM on the asset Plant. Due to inheritance, Reactor 1 and Pump A will receive those same permissions. Reactor 2 has an explicitly defined NO_PERMISSION, causing the inheritance to stop there. As a result, the user will have access to neither Reactor 2 and Pump B.
4. Resources
4.1. Asset
4.1.1. Browse Asset tree on path
GET /asset/browse
Parameters
Type |
Name |
Description |
Schema |
Query optional |
parentPath |
the ltree path to the asset's parent. |
Query optional |
useTimeSeriesIdentifier |
Indicates if the Asset data reference should be resolved to a TimeSeriesIdentifier UUID or not. |
Query optional |
resolveTimeSeriesData |
Indicates if the timeseries data should be resolved for attributes of type DATAREFERENCE. Default is true |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Sorting criteria in the format: property,(asc |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
PagedModelAsset |
Produces
application/json
application/hal+json
4.1.2. Get an asset by its identifier.
GET /asset/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
The identifier of the asset. |
String |
Query optional |
Query optional |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
Asset |
Produces
application/json
4.1.3. Get an asset's attributes using the asset's identifier.
GET /asset/{identifier}/attribute
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
The identifier of the asset for which the attributes are searched. |
String |
Query optional |
query |
You can search on all the exposed properties of a node Available search operators: equal(==), not equal(!=), in(=in=), not in(=out=) Available logical operator; AND(;), OR(,) Wildcards ∗ are supported Examples: search by name equal to node and description not equal to old: name=='node';description!='old' search by name like node or description equal to something name=='∗node∗',description=='something'search by name equal to 'node' and node is child of provided parent path 'A.B.C.D' : name=='node';paths=c='A.B.C.D' search by name like 'node' and node is descendant of provided ancestor path 'A.B' : name=='node';paths=d='A.B' |
Query optional |
Query optional |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
PagedModelAsset |
Produces
application/json
4.1.4. Get an asset by its path. Optionally include its ancestors.
GET /asset
Parameters
Type |
Name |
Description |
Schema |
Query optional |
path |
the ltree path to the asset. |
Query optional |
includeAncestors |
Flag whether to include ancestors or not. |
Query optional |
Query optional |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
PagedModelAsset |
Produces
application/json
4.1.5. Get assets by paths
POST /asset
Parameters
Type |
Name |
Description |
Schema |
Query optional |
Query optional |
Query optional |
includeDeleted |
Indicator whether to include the deleted assets or not. Default is false |
Body required |
PathListModel |
List of paths. |
Produces
application/json
4.1.6. Get relatives for assets by their path
POST /asset/relatives
Parameters
Type |
Name |
Description |
Schema |
Query optional |
limit |
Limit the response size, default is 10001. |
Query optional |
Query optional |
Body required |
RelativesByPathModel |
List of relatives |
Produces
application/json
4.1.7. Get the timeseries data linked to an attribute, identified by its identifier.
GET /asset/{identifier}/timeseriesdata
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
The identifier of the attribute. |
String |
Query optional |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
AssetTimeSeriesData |
Produces
application/json
4.1.8. Search assets matching the specified query.
GET /asset/search
Parameters
Type |
Name |
Description |
Schema |
Query required |
query |
You can search on all the exposed properties of a node Available search operators: equal(==), not equal(!=), in(=in=), not in(=out=) Available logical operator; AND(;), OR(,) If you want to use \\ literally, then double it as \\\\ Wildcards ∗ are supported Examples: search by name equal to node and description not equal to old: name=='node';description!='old' search by name like node or description equal to something name=='∗node∗',description=='something'search by name equal to 'node' and node is child of provided parent path 'A.B.C.D' : name=='node';paths=c='A.B.C.D' search by name like 'node' and node is descendant of provided ancestor path 'A.B' : name=='node';paths=d='A.B' |
Query optional |
Query optional |
unnest |
Unnest asset with multiple paths or not. |
Query optional |
includeDeleted |
Query optional |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
PagedModelAsset |
Produces
application/json
4.1.9. Search assets matching the specified query.
POST /asset/search
Parameters
Type |
Name |
Description |
Schema |
Body required |
NodeSearchParametersModel |
Search assets matching the specified query. |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
PagedModelAsset |
Produces
application/json
4.2. AssetAccessRules
4.2.1. Returns true if there are any other permissions then the default permissions.
GET /asset/accessrule
Parameters
| Type | Name | Description | Schema |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
AccessPermissionsModifiedRepresentationModel |
401 |
Unauthorized |
Produces
application/json
4.2.2. Create an access rule for the specified asset.
POST /asset/{path}/accessrule
Parameters
Type |
Name |
Description |
Schema |
Path required |
path |
The path of the asset. |
String |
Body required |
AssetAccessRuleModel |
The access rule model. |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
AccessRule |
404 |
The resource was not found |
AccessRule |
400 |
Validation failed |
AccessRule |
401 |
Unauthorized |
AccessRule |
Produces
application/json
4.2.3. Delete the specified access rule for the specified asset.
DELETE /asset/{path}/accessrule/{accessRuleId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
path |
String |
Path required |
accessRuleId |
The identifier of the access rule. |
String |
Responses
HTTP Code |
Description |
Schema |
204 |
Deleted |
404 |
401 |
Unauthorized |
4.2.4. Get the specified access rule for the specified asset.
GET /asset/{path}/accessrule/{accessRuleId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
path |
String |
Path required |
accessRuleId |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
AccessRule |
404 |
AccessRule |
401 |
Unauthorized |
AccessRule |
Produces
application/json
4.2.5. Returns ids of access rules collection which were deleted after the given deletedAfter timestamp
GET /asset/accessrule/deleted
Parameters
Type |
Name |
Description |
Schema |
Query required |
deletedAfter |
Timestamp to filter rules deleted after |
Query optional |
lastCheckedId |
UUID of last synchronized rule to be used as tiebreaker when modified timestamps match |
Query optional |
size |
number of records returned in 1 page |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
PagedModelDeletedAccessRule |
401 |
Unauthorized |
Produces
application/json
4.2.6. Returns access rules collection which were modified after input
GET /asset/accessrule/modified
Parameters
Type |
Name |
Description |
Schema |
Query required |
modifiedAfter |
Timestamp to filter rules modified after the given modifiedAfter timestamp |
Query optional |
lastCheckedId |
Query optional |
size |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
PagedModelAccessRule |
401 |
Unauthorized |
Produces
application/json
4.2.7. Get the access rule for the specified asset selected by path.
Parameters
Type |
Name |
Description |
Schema |
Path required |
path |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
List[AccessRule] |
404 |
List[AccessRule] |
401 |
Unauthorized |
List[AccessRule] |
Produces
application/json
4.2.8. Get all inherited access rule for the specified asset.
GET /asset/{path}/accessrule/inherited
Parameters
Type |
Name |
Description |
Schema |
Path required |
path |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
List[AccessRule] |
404 |
List[AccessRule] |
401 |
Unauthorized |
List[AccessRule] |
Produces
application/json
4.2.9. Update the specified access rule for the specified asset.
PUT /asset/{path}/accessrule/{accessRuleId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
path |
String |
Path required |
accessRuleId |
String |
Body required |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
AccessRule |
404 |
AccessRule |
400 |
Validation failed |
AccessRule |
401 |
Unauthorized |
AccessRule |
Produces
application/json
4.3. AssetConverter
4.3.1. Converts a named path to the node identifier.
POST /asset/convert/named-path
Parameters
Type |
Name |
Description |
Schema |
Body required |
NamedPathListModel |
Named path list model |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
MappingsV2 |
Produces
application/json
4.3.2. Converts a node identifier to the named path.
POST /asset/convert/identifier
Parameters
Type |
Name |
Description |
Schema |
Body required |
IdListModel |
Id list model. |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
MappingsV2 |
Produces
application/json
4.4. AssetPermissions
4.4.1. Get the granted permissions for the specified assets for the current user.
POST /permissions
Parameters
Type |
Name |
Description |
Schema |
Body required |
IdListModel |
The list of asset identifiers. |
Responses
HTTP Code |
Description |
Schema |
200 |
The resource was found with the provided permissions |
GrantedPermissions |
404 |
Produces
application/json
4.4.2. Get the granted permissions for the specified nodes for the current user.
POST /node/permission
Parameters
Type |
Name |
Description |
Schema |
Body required |
IdListModel |
The list of node identifiers. |
Responses
HTTP Code |
Description |
Schema |
200 |
GrantedPermissionMap |
404 |
Produces
application/json
4.4.3. Get the granted permissions for the specified structures for the current user.
POST /structure/permission
Parameters
Type |
Name |
Description |
Schema |
Body required |
IdListModel |
The list of structure identifiers. |
Responses
HTTP Code |
Description |
Schema |
200 |
404 |
Produces
application/json
4.5. AssetTreeBuilder
4.5.1. Create new node.
POST /builder/{sourceIdentifier}/node
Parameters
Type |
Name |
Description |
Schema |
Path required |
sourceIdentifier |
The source identifier. |
String |
Query optional |
force |
Forces creation if node with same path and name exists |
Body required |
NodeBuilderModel |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
NodeBuilderRepresentationModel |
Produces
application/json
4.5.2. Create new source.
POST /builder
Parameters
Type |
Name |
Description |
Schema |
Body required |
SourceBuilderModel |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
Source |
Produces
application/json
4.5.3. Delete node.
DELETE /builder/{sourceIdentifier}/node/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
sourceIdentifier |
String |
Path required |
identifier |
The node identifier. |
String |
Query optional |
recursive |
Delete children as well. |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
4.5.4. Update node.
PUT /builder/{sourceIdentifier}/node/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
sourceIdentifier |
String |
Path required |
identifier |
String |
Body required |
NodeBuilderModel |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
Produces
application/json
4.6. Assets
4.6.1. Browse structures based on their path in the asset tree.
GET /assets/structure/browse/{path}
Parameters
Type |
Name |
Description |
Schema |
Path required |
path |
the ltree path to the node. |
String |
Query optional |
Query optional |
includeAncestors |
Flag wether to include ancestors or not. |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
PagedModelStructure |
Produces
application/json
4.6.2. Converts a named path to the node identifier.
POST /assets/convert/named-path
Parameters
Type |
Name |
Description |
Schema |
Body required |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
Mappings |
Produces
application/json
4.6.3. Converts a node identifier to the named path.
POST /assets/convert/identifier
Parameters
Type |
Name |
Description |
Schema |
Body required |
IdListModel |
Id list model. |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
Mappings |
Produces
application/json
4.6.4. Exports the current nodes by their structures.
GET /assets/export
Parameters
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
4.6.5. Checks whether or not the current assets structure can be exported.
GET /assets/exportable
Parameters
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
Boolean |
Produces
application/json
4.6.6. Gets the node denoted by its external id.
GET /assets/node/external/{externalId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
externalId |
String |
Query optional |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
Node |
Produces
application/json
4.6.7. Gets the node denoted by its UUID.
GET /assets/node/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Query optional |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
Node |
Produces
application/json
4.6.8. Gets the structure denoted by its UUID.
GET /assets/{id}
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Query optional |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
Structure |
Produces
application/json
4.6.9. Lists the structures that have a parent defined by parentId. If parentId is omitted, all root structures are returned.
GET /assets/browse
Parameters
Type |
Name |
Description |
Schema |
Query optional |
parentId |
Query optional |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
Produces
application/json
4.6.10. Retrieve the specified list of nodes.
POST /assets/nodes
Parameters
Type |
Name |
Description |
Schema |
Query optional |
Body required |
IdListModel |
List of identifiers. |
Produces
application/json
4.6.11. Retrieve the specified list structures.
POST /assets/structures
Parameters
Type |
Name |
Description |
Schema |
Query optional |
Body required |
PathListModel |
List of paths. |
Produces
application/json
4.6.12. Checks whether or not a new assets structure can be imported.
GET /assets/importable
Parameters
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
Boolean |
Produces
application/json
4.6.13. Search for all child attributes for a specified node that match the optional query pattern.
GET /assets/node/{id}/attributes
Parameters
Type |
Name |
Description |
Schema |
Path required |
id |
UUID |
Query optional |
query |
You can search on all the exposed properties of a node Available search operators: equal(==), not equal(!=), in(=in=), not in(=out=) Available logical operator; AND(;), OR(,) Wildcards ∗ are supported Examples: search by name equal to node and description not equal to old: name=='node';description!='old' search by name like node or description equal to something name=='∗node∗',description=='something' |
Query optional |
Query optional |
parent |
the uuid of the parent structure. |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
PagedModelNode |
Produces
application/json
4.6.14. Search for all structures that match the query pattern.
GET /assets/search
Parameters
Type |
Name |
Description |
Schema |
Query required |
query |
You can search on all the exposed properties of a node Available search operators: equal(==), not equal(!=), in(=in=), not in(=out=) Available logical operator; AND(;), OR(,) If you want to use \\ literally, then double it as \\\\ Wildcards ∗ are supported Examples: search by name equal to node and description not equal to old: name=='node';description!='old' search by name like node or description equal to something name=='∗node∗',description=='something' |
Query optional |
Query optional |
parent |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
Produces
application/json
4.6.15. Search structures matching the specified query.
POST /assets/search
Parameters
Type |
Name |
Description |
Schema |
Body required |
SearchParametersV1Model |
The search parameters. |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
Produces
application/json
4.7. AssetsAccessRulesV1Deprecated
4.7.1. Create an access rule for the specified structure.
POST /assets/{structureId}/accessrule
Parameters
Type |
Name |
Description |
Schema |
Path required |
structureId |
The identifier of the asset's structure. |
String |
Body required |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
AccessRule |
404 |
AccessRule |
400 |
Validation failed |
AccessRule |
401 |
Unauthorized |
AccessRule |
Produces
application/json
4.7.2. Delete the specified access rule for the specified structure.
DELETE /assets/{structureId}/accessrule/{accessRuleId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
structureId |
String |
Path required |
accessRuleId |
String |
Responses
HTTP Code |
Description |
Schema |
204 |
Deleted |
404 |
401 |
Unauthorized |
4.7.3. Get the specified access rule for the specified structure.
GET /assets/{structureId}/accessrule/{accessRuleId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
structureId |
String |
Path required |
accessRuleId |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
AccessRule |
404 |
AccessRule |
401 |
Unauthorized |
AccessRule |
Produces
application/json
4.7.4. Get the access rule for the specified structure.
Parameters
Type |
Name |
Description |
Schema |
Path required |
structureId |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
List[AccessRule] |
404 |
List[AccessRule] |
401 |
Unauthorized |
List[AccessRule] |
Produces
application/json
4.7.5. Get all inherited access rule for the specified structure.
GET /assets/{structureId}/accessrule/inherited
Parameters
Type |
Name |
Description |
Schema |
Path required |
structureId |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
List[AccessRule] |
404 |
List[AccessRule] |
401 |
Unauthorized |
List[AccessRule] |
Produces
application/json
4.7.6. Update the specified access rule for the specified structure.
PUT /assets/{structureId}/accessrule/{accessRuleId}
Parameters
Type |
Name |
Description |
Schema |
Path required |
structureId |
String |
Path required |
accessRuleId |
String |
Body required |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
AccessRule |
404 |
AccessRule |
400 |
Validation failed |
AccessRule |
401 |
Unauthorized |
AccessRule |
Produces
application/json
4.8. GrantedAssetPermissions
4.8.1. Get all assets for which any permissions is set for the a subject.
GET /asset/granted-assets
Parameters
Type |
Name |
Description |
Schema |
Query required |
subjectType |
Subject type |
Query optional |
subjectIdentifier |
Subject identifier |
Responses
HTTP Code |
Description |
Schema |
404 |
The requested subject does not exist. |
GrantedAssetPermissionsRepresentationModel |
204 |
No specific permissions for this user exist. |
200 |
Specific permissions for this user exist. |
401 |
Unauthorized |
Produces
application/json
4.8.2. Get all subject type/identifier pairs.
GET /asset/granted-assets/subjects
Parameters
Responses
HTTP Code |
Description |
Schema |
200 |
All subject type/identifier pairs. |
CollectionModelGrantedAssetPermissionsIdRepresentationModel |
401 |
Unauthorized |
Produces
application/json
4.9. PublicDownloadGenerator
4.9.1. Generate
POST /download/generate
Parameters
Type |
Name |
Description |
Schema |
Body required |
LinkModel |
Responses
HTTP Code |
Description |
Schema |
200 |
Ok |
DataModel |
Produces
application/json
4.10. Source
4.10.1. Create new source.
POST /source
Parameters
Type |
Name |
Description |
Schema |
Query required |
name |
The name of the source. |
Query required |
published |
Indicator whether the source is published or not. |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
Source |
Produces
application/json
4.10.2. Delete existing source.
DELETE /source/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
The identifier of the source. |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
4.10.3. Download error CSV file.
GET /source/{identifier}/history/{syncJobIdentifier}/error
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
String |
Path required |
syncJobIdentifier |
The identifier of the sync job. |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
4.10.4. Download original CSV file.
GET /source/{identifier}/history/{syncJobIdentifier}/original
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
String |
Path required |
syncJobIdentifier |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
4.10.5. Download current version for CSV source.
GET /source/{identifier}/export
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
String |
Query optional |
includeDeleted |
Indicator whether to include the deleted assets or not. |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
4.10.6. List all sources.
GET /source
Parameters
Type |
Name |
Description |
Schema |
Query optional |
query |
Optional RSQL search filter. |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
PagedModelSource |
Produces
application/json
4.10.7. Get specific source by its identifier.
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
Source |
Produces
application/json
4.10.8. List all imports for an existing source.
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
String |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
PagedModelSyncJob |
Produces
application/json
4.10.9. List all imports for an existing source.
POST /source/history
Parameters
Type |
Name |
Description |
Schema |
Body required |
UUID |
List of source identifiers. |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
List[SourceSyncJob] |
Produces
application/json
4.10.10. Get the sync job details.
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
String |
Path required |
syncJobIdentifier |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
SyncJob |
Produces
application/json
4.10.11. Reorder source's root.
POST /source/{identifier}/move
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
String |
Body required |
SourceReorderingModel |
Operation to be applied on the order. |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
Source |
Produces
application/json
4.10.12. Update existing source.
PUT /source/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
String |
Query required |
name |
Query required |
published |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
Source |
Produces
application/json
4.11. Sync
4.11.1. Cancel execution of a specific sync job.
DELETE /sync/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
The sync job's identifier. |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
SyncJob |
Produces
application/json
4.11.2. Get sync history for a specific datasource.
GET /sync
Parameters
Type |
Name |
Description |
Schema |
Query required |
datasourceId |
The datasource identifier. |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
PagedModelSyncJob |
Produces
application/json
4.11.3. Get status for a specific sync job.
GET /sync/{identifier}
Parameters
Type |
Name |
Description |
Schema |
Path required |
identifier |
String |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
SyncJob |
Produces
application/json
4.11.4. Get status for the latest sync job per datasource in bulk.
POST /sync/status
Parameters
Type |
Name |
Description |
Schema |
Body required |
UUID |
List of datasource identifiers. |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
Produces
application/json
4.11.5. Sync a specific datasource.
POST /sync
Parameters
Type |
Name |
Description |
Schema |
Query required |
datasourceId |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
String |
Produces
application/json
4.11.6. Search for sync histories.
GET /sync/search
Parameters
Type |
Name |
Description |
Schema |
Query required |
query |
You can search on all the exposed properties of a sync job Available search operators: equal(==), not equal(!=), in(=in=), not in(=out=) Available logical operator; AND(;), OR(,) If you want to use \\ literally, then double it as \\\\ Wildcards ∗ are supported |
Query optional |
page |
Query optional |
size |
Query optional |
sort |
Responses
HTTP Code |
Description |
Schema |
200 |
OK |
PagedModelSyncJob |
Produces
application/json
5. Models
5.1. AccessPermissionsModifiedRepresentationModel
| Field Name | Required | Type | Description | Format |
modified |
Boolean |
5.2. AccessRule
Represents an access rule definition
identifier |
String |
objectId |
X |
String |
The identifier of the object. |
paths |
X |
List of [string] |
An array of paths towards the object. |
subjectId |
X |
String |
The identifier of the subject. |
subjectType |
X |
String |
The type of the subject: USER, GROUP, EVERYBODY, GUEST. |
Enum: GUEST, EVERYONE, GROUP, USER, |
permissions |
X |
Set of [string] |
A set of permissions the subject has on the specified object. Can be an empty set. |
Enum: |
userDetailsResource |
UserDetails |
structureResource |
Structure |
assetResource |
Asset |
createdDate |
Date |
Access rule creation date |
date-time |
lastModifiedDate |
Date |
Access rule last modified date |
date-time |
links |
List of Link |
5.3. Asset
Represents an asset
identifier |
UUID |
The asset's identifier. |
uuid |
paths |
List of [string] |
The paths towards this asset starting from the root. |
longPaths |
List of [string] |
The old longer paths towards this asset starting from the root. |
parentNames |
List of [string] |
The names of the parents, in the same order as the paths. |
name |
String |
The asset's name. |
description |
String |
The asset's description. |
type |
String |
The asset's type. |
dataType |
String |
The asset's data type, if the Asset is an ATTRIBUTE. |
data |
String |
The asset's data, if the Asset is an ATTRIBUTE. (tagName or UUID) |
timeSeriesDefinition |
TimeSeriesDefinitionRepresentation |
deleted |
Boolean |
Indication whether this asset is deleted or not. |
externalId |
String |
The asset's identifier in the external system. |
template |
String |
The asset's template. |
templateId |
String |
The asset's template identifier. |
source |
Source |
permissions |
Set of [string] |
The asset's permissions. |
Enum: |
createdDate |
Date |
The asset's creation date |
date-time |
lastModifiedDate |
Date |
The asset's last modified date |
date-time |
links |
List of Link |
5.4. AssetAccessRuleModel
Object used for creating and updating an access rule
identifier |
String |
subjectId |
X |
String |
subjectType |
X |
String |
The type of the subject. |
permissions |
X |
Set of [string] |
A set of permissions the subject has on the specified object. |
Enum: |
5.5. AssetTimeSeriesData
data |
String |
timeseriesDefinition |
links |
List of Link |
5.6. CollectionModelGrantedAssetPermissionsIdRepresentationModel
links |
List of Link |
content |
5.7. DataModel
data |
String |
the signed link data |
5.8. DeletedAccessRule
Represents a deleted access rule
identifier |
UUID |
uuid |
deletedAt |
Date |
The date of deletion of the access rule. |
date-time |
links |
List of Link |
5.9. GrantedAssetPermissionsIdRepresentationModel
Represents a granted asset permission identifier.
subjectType |
String |
The subject's type. |
subjectIdentifier |
String |
The subject's identifier. |
links |
List of Link |
5.10. GrantedAssetPermissionsRepresentationModel
Model holding a list of asset identifiers for which the user has any permission.
assetIdentifiers |
List of [UUID] |
uuid |
subjectIdentifier |
String |
subjectType |
String |
links |
List of Link |
5.11. GrantedPermission
List of granted permissions
assetIdentifier |
UUID |
uuid |
sourceIdentifier |
UUID |
uuid |
permissions |
Set of [string] |
5.12. GrantedPermissionMap
Represents granted permissions for bulk permission resolving
permissions |
Map of [set] |
Map of granted permissions per node/structure id. |
5.13. GrantedPermissions
Represents granted permissions for an Asset
permissions |
List of GrantedPermission |
List of granted permissions |
5.14. IdListModel
uuidList |
List of [UUID] |
List of asset identifiers. |
uuid |
5.15. Link
rel |
String |
href |
String |
hreflang |
String |
media |
String |
title |
String |
type |
String |
deprecation |
String |
profile |
String |
name |
String |
5.16. LinkModel
link |
X |
String |
The requested link. |
validity |
Long |
int64 |
5.17. Mapping
List of mappings.
path |
String |
Path of the asset. |
identifier |
String |
Identifier of the asset. |
5.18. MappingV2
List of mappings.
namedPath |
String |
identifier |
String |
longPath |
String |
Path of identifiers to the asset. |
path |
String |
Path of short identifiers to the asset. |
5.19. Mappings
mappings |
List of Mapping |
List of mappings. |
links |
List of Link |
5.20. MappingsV2
mappings |
List of MappingV2 |
List of mappings. |
links |
List of Link |
5.21. NamedPathListModel
namedPathList |
List of [string] |
List of paths built up using asset names. |
5.22. Node
identifier |
String |
The node's identifier |
sourceId |
String |
Deprecated notion of source. |
type |
String |
Node's type. |
externalId |
String |
Node's external identifier. |
template |
String |
Node's template name. |
templateId |
String |
Node's template identifier. |
name |
String |
Node's name. |
description |
String |
Node's description. |
dataType |
String |
Node's data type in case this node is an ATTRIBUTE. |
data |
String |
Node's data in case this node is an ATTRIBUTE. |
options |
String |
Node's options. |
deleted |
Boolean |
Idicates whether this node is deleted. |
permissions |
Set of [string] |
Node's permission for the requesting user. |
Enum: |
paths |
List of [string] |
longPaths |
List of [string] |
links |
List of Link |
5.23. NodeBuilderModel
Represents a model to build an asset tree
parentPath |
X |
String |
Parent node's short path. |
name |
X |
String |
Node's name. |
description |
String |
tag |
String |
Tag the ATTRIBUTE refers to. |
5.24. NodeBuilderRepresentationModel
Represents a node in the asset tree builder
identifier |
UUID |
Node's identifier. |
uuid |
sourceIdentifier |
UUID |
Source's identifier. |
uuid |
parentPath |
String |
Parent node's path. |
name |
X |
String |
Node's name. |
description |
X |
String |
tag |
String |
links |
List of Link |
5.25. NodeSearchParametersModel
Represents search parameters
query |
X |
String |
value = "You can search on all the exposed properties of an asset.\\n\\n" + "Available search operators:\\n" + "equal(==), not equal(!=), in(=in=), not in(=out=)\\n" + "\\n" + "Available search operators for 'paths' property :\\n" + "child of (=c= or =child=), descendant of (=d= or =descendant=)\\n" + "\\n" + "Available logical operator;\\n" + "AND(;), OR(,)\\n" + "\\n" + "Wildcards ∗ are supported\\n\\n" + "Examples:\\n" + "search by name equal to 'node' and description not equal to 'old': name=='node';description!='old'\\n\\n" + "search by name like 'node' or description equal to 'something': name=='∗node∗',description=='something'\\n\\n" + "search by name equal to 'node' and node is child of provided parent path 'A.B.C.D' : name=='node';paths=c='A.B.C.D'\\n\\n" + "search by name like 'node' and node is descendant of provided ancestor path 'A.B' : name=='node';paths=d='A.B'" |
page |
Integer |
int32 |
size |
Integer |
int32 |
sort |
List of [string] |
Boolean |
Indicates if the Asset data reference should be resolved to a TimeSeriesIdentifier UUID or not. Default is true |
unnest |
Boolean |
includeDeleted |
Boolean |
Defines, if deleted nodes should be shown. |
Boolean |
5.26. PageMetadata
size |
Long |
int64 |
totalElements |
Long |
int64 |
totalPages |
Long |
int64 |
number |
Long |
int64 |
5.27. PagedModelAccessRule
links |
List of Link |
content |
List of AccessRule |
page |
PageMetadata |
5.28. PagedModelAsset
links |
List of Link |
content |
List of Asset |
page |
PageMetadata |
5.29. PagedModelDeletedAccessRule
links |
List of Link |
content |
List of DeletedAccessRule |
page |
PageMetadata |
5.30. PagedModelNode
links |
List of Link |
content |
List of Node |
page |
PageMetadata |
5.31. PagedModelSource
links |
List of Link |
content |
List of Source |
page |
PageMetadata |
5.32. PagedModelStructure
links |
List of Link |
content |
List of Structure |
page |
PageMetadata |
5.33. PagedModelSyncJob
links |
List of Link |
content |
List of SyncJob |
page |
PageMetadata |
5.34. PathListModel
pathList |
List of [string] |
5.35. RelativesByPathModel
path |
String |
Path of the asset |
include |
String |
Type to include |
Enum: SELF, ANCESTORS, DESCENDANTS, |
5.36. SearchParametersV1Model
Represents search parameters for assetsV1
query |
X |
String |
page |
Integer |
int32 |
size |
Integer |
int32 |
sort |
List of [string] |
Boolean |
unnest |
Boolean |
includeDeleted |
Boolean |
Boolean |
parent |
String |
5.37. Source
Represents a source
identifier |
UUID |
The source's identifier. |
uuid |
name |
String |
The source's name. |
type |
String |
The source's type. |
Enum: DATASOURCE, CSV, |
externalId |
String |
The source's external identifier. |
ordering |
Integer |
The source's order in the root asset tree. |
int32 |
published |
Boolean |
Indicates whether he source is published. |
lastSyncDate |
Date |
date-time |
permissions |
Set of [string] |
The source's permissions for the requesting user. |
Enum: |
links |
List of Link |
5.38. SourceBuilderModel
Represents a model to create an asset tree
name |
X |
String |
published |
Boolean |
5.39. SourceReorderingModel
operation |
String |
Enum: UP, DOWN, TOP, BOTTOM, |
5.40. SourceSyncJob
source |
Source |
syncJob |
SyncJob |
5.41. Structure
Structure details for enriched inherited calls.
structureIdentifier |
String |
sourceId |
String |
parentStructureId |
String |
nodeIdentifier |
String |
type |
String |
externalId |
String |
template |
String |
templateId |
String |
name |
String |
parentName |
String |
description |
String |
dataType |
String |
data |
String |
options |
String |
deleted |
Boolean |
path |
String |
permissions |
Set of [string] |
Enum: |
links |
List of Link |
5.42. SyncJob
identifier |
UUID |
uuid |
name |
String |
The sync job's name. |
started |
Date |
The moment the sync job started. |
date-time |
ended |
Date |
The moment the sync job ended. |
date-time |
status |
String |
The sync job's status. |
Enum: SCHEDULED, RUNNING, DONE, DONE_WITH_ERRORS, CANCELLED, FAILED, |
triggeredDate |
Date |
The moment the sync job was triggered. |
date-time |
triggeredBy |
String |
The user the sync job triggered by. |
errorMessage |
String |
The sync job's error message, if any. |
source |
Source |
links |
List of Link |
5.43. TimeSeriesDefinitionRepresentation
TimeSeries definition to which the data points. Can be empty, even if data is present.
datasourceId |
UUID |
uuid |
ownerId |
String |
externalId |
String |
name |
String |
description |
String |
type |
String |
units |
String |
interpolationType |
String |
datasourceType |
String |
deleted |
Boolean |
plotDataUrl |
String |
indexDataUrl |
String |
links |
List of Link |
id |
UUID |
uuid |
5.44. UserDetails
Represents a subset of user details
userId |
String |
User's id. |
userName |
String |
User's username. |
firstName |
String |
User's first name. |
lastName |
String |
User's last name. |
admin |
Boolean |
Indication whether user is an admin or not. |
